Accidentally deleted some harvest data on JD Ops center. Anything be done?
cyclones30
Posted 11/24/2025 10:32 (#11445492 - in reply to #11443749)
Subject: RE: Accidentally deleted some harvest data on JD Ops center. Anything be done?
Midwest
jermrief - 11/22/2025 16:38 Go to More > Files > Work Data. Do a search for the field you have missing and rough date range. Select the fields in question (most likely there will be multiple files listed) and click reprocess at the top and wait 30min or so.
This ^^
Find your files for those fields on the files page and use the date range and file names as hints. Check the boxes and reprocess
