Search Forums | Classifieds (44) | Skins | Language
IH 1640 (later model SN#)
HuskerJ
Posted 11/5/2025 09:00 (#11424736 - in reply to #11424425)
Subject: RE: IH 1640 (later model SN#)
East of Broken Bow
Yup, cab solenoid, or a loose ground seems most likely. Remove the panel on the RH side of the cab, and you should find it pretty easy.
Be sure to replace it with a cab solenoid, not a starter solenoid, as a starter solenoid is not rated for continual use and will not last very long when used that way.
