John Deere dry rate controller and switching displays?
kjs3
Posted 11/2/2025 14:00 (#11421874)
Subject: John Deere dry rate controller and switching displays?
se wi
I started using a dry fertilizer spreader with a 4640 display and jd rate controller on the spreader this summer. Now that display is in a combine and I'd like to spread fertilizer. I have a 2630 display I can put in the tractor. Will this work? Do I have to re enter the cal #s and calibrate again? Is this info in rate controller or display? Thanks for your input
