Search Forums | Classifieds (34) | Skins | Language
Tier 3 Magnum - PRO 700 - Guidance ??
WinstonWolf
Posted 11/1/2025 11:01 (#11420712)
Subject: Tier 3 Magnum - PRO 700 - Guidance ??
Southern MN
I have a 2009 Magnum that came from the factory with option "420763000-AUTOGUIDANCE READY CLASS 5". I would like to add a PRO 700 to the tractor to run the auto steering and also because I would like to see all the tractor data displayed on a screen, vs the corner post.
Starting from scratch (pulling out the existing EZ Guide 500 stuff in it now), I'm assuming I will need the following:
PRO 700 display with software loaded for a tractor
372 GPS receiver
Accuguide Controller
Some wiring harness for the 700??
Am I missing anything?
Assuming all the harnessing is there, aside from the 700 connection harness.
Likely searching for used stuff, I don't want to spend a huge amount and don't need anything better than WAAS, as this is just a tillage tractor.
