Search Forums | Classifieds (34) | Skins | Language
Active Yield JD S660
Oxford
Posted 10/29/2025 07:54 (#11416933)
Subject: Active Yield JD S660
S W Ontario
Have a 2016 JD S660 with Active Yield installed about 4 yrs ago. Has worked fine until recently. It will show that it is ready to calibrate when the bin is empty and as you start harvesting it will say it is collecting. However after harvesting for a ways it will say "load rejected inconsistent flow" . Although the corn is variable this year I have tried it in areas where it is fairly consistent with the same results. Have checked the wiring harness in the grain tank for chewed wires or poor connections and found nothing. any advice as where to look next would be appreciated. Thanks
