 Eastern Nebraska | If you go into the Analyze dropdown, then click Work Analyzer, you can filter what you want for data, like 2025 corn harvest. Then in the top right corner, you can hit Share/Export, then Work Data. Then click Export Work Data and give the file name a name you'll recognize. This will export out whatever data you had filtered as shapefiles.
Because I work with SMS and Op Center, I export out a lot of work data this way, usually filtering it by crop type. Then I can bulk import the shapefiles into SMS with a template. Works pretty slick. | |
