Search Forums | Classifieds (72) | Skins | Language
Need battery disconnect for 06 Duramax
WeatherBug
Posted 10/9/2025 18:58 (#11394804 - in reply to #11394766)
Subject: RE: Need battery disconnect for 06 Duramax
Bottom of the Mitten
Chasing down a battery draw is not difficult. Just need a DVOM. There's probably youtube videos if you're unsure how. Fixing it correctly would be easier than adding a disconnect. If you choose to add the disconnect you'll need to mount it very close to the battery(s) because the draw might be something very close to one of the batteries.
Edit: Diagnosing it very easy. It depends what the problem is as to how easy ot costly of a fix it is
Edited by WeatherBug 10/9/2025 19:05
