Search Forums | Classifieds (71) | Skins | Language
6140 Sidehill Sieve Loss
Crossflow
Posted 10/9/2025 18:54 (#11394801 - in reply to #11394792)
Subject: RE: 6140 Sidehill Sieve Loss
SE MN
Good suggestions by JohnW.
Regarding the pinch point, do a kill stall of the combine and flat land and make sure the material is distributed level left to right. If too much material is on the left side, move the pinch point to a higher number bar (move pinch point further to the right). Pinch point adjustment method is typically detailed in the operators manual.
The rubber paddle on the far left auger can help fling material to the right a little. If its not engaging the crop, move it down closer to the grain pan. Verify the far left auger is reverse flighting direction from the other augers.
