Search Forums | Classifieds (129) | Skins | Language
No cab heat in flagship 8230 combine.what usually is the issue?
School Of Hard Knock
Posted 10/10/2025 00:07 (#11395142 - in reply to #11394483)
Subject: RE: No cab heat in flagship 8230 combine.what usually is the issue?
Central ND
179 - 184. Its been cool out and the load hasn't been very big..
I cant answer about the heater shutoff valves because I didn't look. If you turn the thermostat from 68 to 72 after sundown, it will blow some warmth for less than a minute and its all over. If the window fogs over and you turn on the defrost it quickly chills and takes the moisture off but you never get heat for more than half minute and its just AC blowing then.
Ill have to look for the 3 valves in the morning. Someone mentioned there are 3 of them. So there must be 3 hoses too.
