Calibrating a Greenstar rate controller?
KRK
Posted 10/9/2025 07:14 (#11394139 - in reply to #11394049)
Subject: RE: Calibrating a Greenstar rate controller?
1 1/4 mile south of Tedbear
Yes, raising the meter cal will apply more.
Current meter cal. X monitor volume ÷ actual volume used = new meter cal.
If the problem has been getting worse, I would suggest looking at the flow meter.
If the flow meter is worn, it turns harder = more product going through to spin the same amount of turns.
