Incommand 1200: RTK via NTRIP, accuracy with manual steering?
Nate B.
Posted 9/8/2025 20:36 (#11358941)
Subject: Incommand 1200: RTK via NTRIP, accuracy with manual steering?
Bremen, KS
After setting up a local base feeding RTCM 3.0 positions to RTK2GO, I was able to set up the stream in the steering section of Setup for the combine where we do not have a steering module so Manual Guidance is active. The GNSS satellite icon is green and the Autoswath on the lower right of the display is also green. Meanwhile looking at the GNSS receiver details, the position error is shown at around 16 inches.
With this combination, is RTK actively applied to the positioning for map drawing of the passes and calculating the resulting covered acres?
