Search Forums | Classifieds (16) | Skins | Language
Header height auto contour on new x9 drops off when raising the header slightly
Fingers77
Posted 7/23/2025 14:03 (#11307029 - in reply to #11306135)
Subject: RE: Header height auto contour on new x9 drops off when raising the header slightly
WAG, but with a Lex, you were most likely were taking it in and out of auto by muscle memory.
Left/Right of the header height control is manual up/down, but up/down is auto up and down presets.
If you manually raise or lower a Lex, it stays where it's set at height wise and tilt wise until you re engage auto by pushing down on the button.
It's all done with the same rocker button on a Lex so maybe that's the issue?
