Search Forums | Classifieds (3) | Skins | Language
Rogator RG 900 Autosteer Issues - Agleader Steercommand Z2
sunman
Posted 7/14/2025 08:05 (#11296685 - in reply to #11295404)
Subject: RE: Rogator RG 900 Autosteer Issues - Agleader Steercommand Z2
North Central Ohio
We think our steering cylinders are getting slightly out of phase. It will work fine for a while, then get worse as we go. If you phase the cylinders (steer full left and right and hold it there) it will work again for a while. We are actually going to switch it to steadysteer and try it. I battled a weave on a combine one time and a steadysteer worked perfectly. That machine, going down the road, you had to constantly turn the wheel slowly to keep it straight. The steadysteer didn't care, it drove perfectly in the field. I wish agleader's integrated systems wouldn't rely so much on a wheel angle sensor.
Any you are correct - AgLeader's display is much better!
