Search Forums | Classifieds (4) | Skins | Language
JD 2630 not sending yield map to Op center
BB in NC
Posted 7/4/2025 11:36 (#11285821 - in reply to #11280020)
Subject: RE: JD 2630 not sending yield map to Op center
Eastern NC
yes I have looked at the memory tab, and I did try to resend/export the file to Op Center via the MTG. (other fields did send just fine before and after that one). The attempt to re-export seems to have worked on the 2630 but not in Op center. Still no yield map.
I will try to be very careful with header changes. I am sure that I intended to only change the swath width, but obviously something was not good and there is a good chance that while frustrated with the driving conditions I changed the wrong measurement.
