Raven 4400 Blows fuse
Pierwszy
Posted 6/26/2025 18:29 (#11276620)
Subject: Raven 4400 Blows fuse
Have a Raven 4400 for applying 28% side dress. It's connected to an AccuBoom unit with for a 3 shut off boom sections. System worked great last year for 28% and sparying.
Have a power strip in the cab, it runs the Raven 4400, AccuBoom, CR7, and a Passive CAN terminal to connect all 3 units. All are connected to the power strip independently. Raven 4400 is getting speed through the CR7 and CR7 displays what sections should be shutoff, but has to be done manually on 4400 as CR7 is not compatible with 4400.
Can power up the the Raven 4400, change values and settings, as soon as turn master switch from OFF to ON 4400 it blows the inline fuse (15 amp).
I've isolate the 4400 console cable and tested, still blows the in line fuse. I'm thinking it might be something internal to the Raven 4400....
Any suggestions?
Thanks.
Edited by Pierwszy 6/26/2025 18:36
