Search Forums | Classifieds (122) | Skins | Language
Agleader 9670 combine kit with ontrac2+
Boomer24
Posted 6/25/2025 08:37 (#11274759 - in reply to #11274079)
Subject: RE: Agleader 9670 combine kit with ontrac2+
SESD
I'll try attaching the installation manual. It has a diagram that shows the Ontrac 2+ cables CAN connections will have an end that connects to the display cables CAN connector and then has a spot for other CAN cables to connect to.
You'll likely have to run another power cable from somewhere to power the Ontrac 2+. "Normal" Ag Leader power cables have the pink guidance power. Combine kits power cables usually get power from the accessory plug or under the cab and don't usually the the guidance power.
Attachments 602-0208-02-A_INST_MDU_OnTrac2+.pdf (5926KB - 1 downloads)
