Search Forums | Classifieds (122) | Skins | Language
Greenstar rate controller question
jmichael8430
Posted 6/26/2025 14:48 (#11276440 - in reply to #11273807)
Subject: RE: Greenstar rate controller question
Frankfort, Indiana
Do you have an air bleed valve near your solution pump? That can help reduce the solution pump dry message. Unfortunately, this message pops up when master is engaged but your target rate is still at zero. If you have a height switch installed that may help your problem as well.
