Search Forums | Classifieds (108) | Skins | Language
JD auto turn Question
jmichael8430
Posted 6/15/2025 09:03 (#11262408 - in reply to #11261445)
Subject: RE: JD auto turn Question
Frankfort, Indiana
It should be in your Turn Automation Settings. if its not at the bottom of your screen on a tab you have to access it through menu on the bottom right corner. once you click the tab you should be able to change settings and turn it on. Check and see what current software you are on. 25-1 changed the way you setup turn automation and its a lot easier.
