South cental Ohio | Can or how do you set the PWM so it will be at say "125" when I start the machine? Mine starts out at "80" and that's not fast enough to make the pump come on to load the sprayer. I can manually set/turn the PWM up to the 125 ( which involves going into the setting which is a pain every time) but I'd like it to be at 125 when I start loading. | |
