Search Forums | Classifieds (37) | Skins | Language
Krone 323s gear box help
muddrunner
Posted 6/9/2025 21:29 (#11256115)
Subject: Krone 323s gear box help
Westphalia Texas [central texas]
Need help on how to get the backlash correct. Is there a procedure to set one gear in the gear box with the right shims, and install other gear .  No way to see depth of mating gears once installed . Do just use the old shim packs, using old gear set. Tia
