Search Forums | Classifieds (29) | Skins | Language
S670 variable speed feeder house
WR460
Posted 6/9/2025 18:54 (#11255866 - in reply to #11255847)
Subject: RE: S670 variable speed feeder house
Shawneetown Illinois
That happened to me on a 2014 S670. Our problem was that the aluminum valve block on the left side of the machine had a crack internally, letting oil bypass and do what you just described. Replaced that, which was several thousand dollars, and it solved the problem.
