Search Forums | Classifieds (8) | Skins | Language
How to tie mapping in JD 2600 to drill on/off switch?
WCGrad
Posted 6/5/2025 20:32 (#11250861 - in reply to #11250753)
Subject: RE: How to tie mapping in JD 2600 to drill on/off switch?
WC Ohio
Depends on the harness but if you have an implement switch connection on the back of the tractor you would just need to tie it into the clutch switch. The 2600 can be set up to normally open or normally closed switch depending on how the drill is wired.
