Hennepin, IL | No new cables. If your setup uses a CCM (switchbox), youll need the CCM for a Gen 2, they look similar and operate the same but are very different. Also if youre using Clinate Fieldview, you wont need the external module and adapter harness anymore. The Ipad will plug directly into the Gen 2 with just a charge cord. Everything else will plug and play. | |
