Posted 5/30/2025 22:25 (#11244344 - in reply to #11244192) Subject: RE: starfire 3000 takes a long time get to 100%
Northern Indiana
That is typical performance, and actually faster than most will see
You can increase time on after shutdown in the setup tab if the StarFire (if machine is parked outdoors under clear sky)
Other than that, you'll need to upgrade to RTK or a newer model
