Search Forums | Classifieds (28) | Skins | Language
Steer Command Z2 poor performance
ShopTeacher
Posted 5/30/2025 07:45 (#11243564 - in reply to #11243414)
Subject: RE: Steer Command Z2 poor performance
NW MN
What tractor? Are you using an SCM mount plate that is attached to something solid, not just the floor mat?
The guess rows is a question I get often. Usually it is a planter that doesn’t pull straight. To check, drive the tractor on a guidance line with the planter raised. Then come back on the same pass in the opposite direction. If the tires are off of the previous mark you need to recalibrate you tilt compensation or your GPS antenna is not centered. If the tire match perfectly it is the planter.
Tuning the Steering Aggressiveness and Online Response should help with the wiggling.
