Search Forums | Classifieds (20) | Skins | Language
Converting7200 ME2 to ISO and going thru JD 2630
mtfarmbro
Posted 5/29/2025 14:25 (#11242893 - in reply to #11242506)
Subject: RE: Converting7200 ME2 to ISO and going thru JD 2630
JAnderson - 5/29/2025 08:46
I would go with Deere seedstar 2xp or newer. That will give you singulation, spacing, etc. with Deere ECU you can split screen the 2630 (guidance on top of screen, planter info on bottom). With a true ISO ECU you have to hit the menu tab to switch back and forth between screens which gets old quickly.
so are you suggesting two different things?? 1. Your preference, to leave the 2630 alone for guidance only, and add a different monitor, a seed star 2xp?? And the 2) is what i am looking into by split screening the 2630??
