 Butterfield, MN | I didn't expect to see a physical cable with Port A on it, figured you could plug it right into the back, but this would probably work, if another plug on that cable is already plugged into the physical "Port A" on the back of the Cruizer itself. It should auto-detect the GPS coming in on port A, so you can just unplug the coax cable. | |
