Where to verify rtk is working on IC1200 with 7500
Boomer24
Posted 5/5/2025 13:39 (#11214761 - in reply to #11214156)
Subject: RE: Where to verify rtk is working on IC1200 with 7500
SESD
aNullValue is correct with all the settings in the display. You didn't mention if you have the 4005505-12 aux to serial cable that will go from the large connector next to the main display cable connection to the Port B end of your dual port GPS 7500 antenna cable. Without that you'll likely see a green satellite icon with a yellow triangle with an exclamation point in it. That means you've got WAAS but not the correction you're set to, RTK External in this case.
