NW Iowa | I have a Kinze 3660 ASD planter that I am having issues with the Case Drain overflow. I noticed this moring that I awas getting oil out of the overflow port on the valve block. I replaced my ASD fan motor today after noticing that because it was bad. Now I am still getting flow out of the overflow valve. I also replaced the 35PSI "popit" valve on the valve block thinking that was the issue but that did nto fix it. When pulling the Case Drain off the tractor and removing the tip, I only have a small stream coming to the tractor while still having the overflow leaking out oil. I am fresh out of ideas and wondering if anyone have some thoughts. Thanks! | |
