Search Forums | Classifieds (13) | Skins | Language
12 row FF 7200 center flex planter
NGU44
Posted 4/15/2025 16:38 (#11190419 - in reply to #11190385)
Subject: RE: 12 row FF 7200 center flex planter
I had one where the linkage got sloppy and had to go back with a plier and make sure the valves were open or closed when lever moved one way it opened two valve the other way the other two valves I think the pin get worn move the handle back and forth and observe how it works but I think I but a pliers on those little blocks to completely open Hope this helps I put up with mine cause that valve isn’t cheap and their are different styles for different years
