SOIL | CNH guidance, DigiFarm and 20/20 is a known combo that doesn't work. I had issues years ago and it ended up costing me substantially in spots that were improperly planted, so I won't trust CNH systems for anything other than steering again.
What I did to get around that was to switch the tractor over to Deere guidance and kept using DigiFarm and it worked as it should. I've read here that most who run CenterPoint RTX or other corrections don't have issues either.
Any way you go, CNH and 20/20 left such a horrible impression on me that I will never run those systems again. You could make the case that DigiFarm is at fault here, but it's simply a correction provider that nobody else seems to have problems with.
