Search Forums | Classifieds (7) | Skins | Language
I just bought an used integra
Rod Maker
Posted 2/4/2025 22:13 (#11089606)
Subject: I just bought an used integra
Westport, IN
I currently run a raven 440 controlled by the versa through an application rate module. This is used to control a Wilmar spreader VRA and a 6/11 kinze planter seed rate VRA. The raven controls a PWM valve on the tractor and encoders on the planter/spreader provide the feedback. I also use a sensor 1 planter monitor to watch the seed rate. This is all set up with an ontrac 3 in an Oliver 1955. It has ran almost flawlessly for 12 years.
For various reasons we are wanting to set it up in a "Modern" White 100. In an attempt to run this and keep the cab "cleaner" what is needed to make this happen using Ag Leader modules with the used Integra I bought? This integra has Multi product unlock. I want to remain compatible with the "1955" while leaving the 1955 intact as it is now. I have several raven monitors that can handle the PWM, but I would rather try Ag leader modules for simplicity.
Seed tube Monitor Module. I have the Dickey John sensors.
Planter control module, direct command, or ????? to control PWM valve on the tractor. Can this be fooled to run the Wilmar spreader they way i do in the application rate module?
Clutch Module I don't currently have but would like to get.
Switchbox??
What is all needed? Most will be bought used if possible. If it gets to expensive I will probably just drive the 1955 another year until I can piece this together.
