Search Forums | Classifieds (61) | Skins | Language
Caseih Pro 1200
NEIA87
Posted 2/3/2025 10:43 (#11086927 - in reply to #11086848)
Subject: RE: Caseih Pro 1200
Yes to both of your questions. The Pro 700+ is a drop-in replacement as long as you are not running a 2008 and older planter, AccuControl (rate and section with Trimble modules) or Electristeer. It will function the same as the Pro700, just a lot faster, a lot better screen, and overall just better. You can put a Pro1200 in as well but it's not a simple drop-in replacement as the Pro700+. It will need some additional harnessing, controller, and Vector Pro GPS receiver so the cost would be greater than just putting in a Pro700+.
If you are running anything ISO currently, I would looking to the Pro700+ as a replacement. It seems to work better than both the Pro700 and Pro1200, even though the Pro1200 is the latest and greatest.
