Search Forums | Classifieds (58) | Skins | Language
CNH Intellisteer to John Deere Autotrac Visa Versa
NDKFarms
Posted 1/28/2025 20:46 (#11078551)
Subject: CNH Intellisteer to John Deere Autotrac Visa Versa
All, this in some information that was provided to me after we purchased a machine that had the John Deere Autotrac system on it. I proceeded to install the original nav system that came with the tractor. The original system that came in the tractor is as follows. Intelliview 3 monitor, Trimble Nav 2 controller, New Holland 372 receiver on the roof.
I received the following fault codes after installing all of the original software. Came to find out that three pins need to be moved back from the 40 pin connector to the 24 pin connector.
Fault codes on the Intelliview 3 display that were received are as follows.
Nav-169 - Steering Column Manual Override Sensor
Nav-040 - Steering Sensor Voltage Low (Note: this is the sensor at the pivot point on T9 or Steiger 4wd tractors)
Please see the attachment for the full run down on everything. I figured this is good info to share since dealers like to keep everything under lock and key.
Edited by NDKFarms 1/28/2025 20:59
Attachments 600 AutoTrac Control Install Deere-1.pdf (12673KB - 286 downloads)
