Search Forums | Classifieds (87) | Skins | Language
Fork truck for the farm?
MaineFarmer
Posted 11/30/2024 05:59 (#10988526 - in reply to #10988196)
Subject: RE: Fork truck for the farm?
coast of Maine
I will say do NOT get one with clutch.The autos with two pedals are there for reason,one pedal stops the trans from trying to move as you raise the mast,the other will act like an auto trans car in gear as you raise the mast.Pnuematic tires important.Cage important.Heighth Limit to get into a semi body is important,check wear on steering linkages under counter weight,(usually overlooked with grease gun),side shift super important,if you get a monster you wont be going into a semi box,no forks over 48 inch if you use pallets a lot.OOne of the coldest jobs in the winter is riding in a forklift in the yard.
