Search Forums | Classifieds (90) | Skins | Language
John Deere 8320 front lights
7130guy
Posted 11/29/2024 15:05 (#10987800)
Subject: John Deere 8320 front lights
2003 8320. Tractor has the Larson LED light kit installed 2 years ago. On low beam everything works correctly. When I flip it to hi beam the upper rear work lights come on as they should. The 2 outside work lights on the front of the nose go out completely. On low beam they work as they should with only 3 bulbs internally per light lit up. I wondered about the relay so swapped it, no change . Not seeing any fuses blown. It started this part way through fall. Sometimes it worked as it should other times not. Now seems to be not working right consistently. Any ideas? TIA
