AgraGPS bridge problems
cyclones30
Posted 10/30/2024 11:46 (#10944353 - in reply to #10943904)
Subject: RE: AgraGPS bridge problems
Midwest
Did you do what was recommended in the picture? You want the higher accuracy receiver on the cab roof and you can run about anything on the implement and it'll share the higher level signal off the cab one.
Make sure (triple check) your measurements are correct. Machine ones, implement ones, implement receiver ones, imp receiver mount direction. In front of or behind implement axle etc. Dealer should have a guide to do all that setup
