Butterfield, MN | Oops, that's a SmarTrax node. I assumed it was still the old long box being it's a 2010. You'll have a Steer Switch indicator of some type in your field computer in the SmarTrax section that you should be able to watch change when you turn the wheel or unplug cabling. There should be at least a round 10-pin plug not too far away from that node that heads down to the valve and pressure switch that you could try unplugging, just in case that cable is bad. From the testing you've done, I'm wondering if there isn't an issue in the SmarTrax node itself. | |
