Search Forums | Classifieds (74) | Skins | Language
Scratch remover for plastic
Cooperator
Posted 7/10/2024 15:23 (#10805606 - in reply to #10805552)
Subject: RE: Scratch remover for plastic
Central Alberta
Indianajones - 7/10/2024 13:25
Lexan or plastic, once it is scratched it is done. A good glass shop should be able to cut you a new piece to fit.
INDY
I disagree. That's what a merchant wants you to believe.
Metal polishing paste contains a fine grit that works quite well to remove small scratches in plastic.
It also contains a clear coat to protect it and make it more shiny.
