Gleaner/fieldstar 2 yield monitor GPS
co2shaun
Posted 7/8/2024 08:54 (#10802654 - in reply to #10802587)
Subject: RE: Gleaner/fieldstar 2 yield monitor GPS
NW KS
Right now I have 2 GPS receivers on the roof. The one for a yield monitor plus another Trimble RTK receiver that runs a Reichhardt steering system. I was thinking about running everything off one receiver and possibly even using the factory wiring harness that goes up to the bin. Do you know if I will run into issues feeding the yield monitor a higher hz Nmea string? What I would like to known on the wiring is if it branches off to any other plug in the cab or if the TX and RX lines from the harness in the bin go directly from there to the yield monitor plug. Year of the machine is a 2003.
