Search Forums | Classifieds (50) | Skins | Language
Artex Manure Spreader VR controlled by Raven
delta1860
Posted 7/3/2024 13:05 (#10797036 - in reply to #10796379)
Subject: RE: Artex Manure Spreader VR controlled by Raven
NE Indiana
Judging by the picture on that link the controller is a Raven RCM which is an ISO controller. You should be able to just plug the ISO cable into the tractor and any ISO screen will control it, if you don't want to use the Raven RCM you could get a JD 2000 rate controller. Raven made the JD 2000 so the cables are interchangeable between the RCM and JD 2000.
