Search Forums | Classifieds (130) | Skins | Language
new holland ls 160 EIC problems and no start
   Forums List -> FAQ & SupportMessage format
Rhubarb
Posted 6/19/2024 06:33 (#10779630 - in reply to #10736952)
Subject: RE: new holland ls 160 EIC problems and no start
It sounds like a possible electrical issue beyond just the battery. The constant beep might be an error code or alert. Check all the fuses and connections to make sure nothing's loose or corroded. Sometimes, the battery terminals themselves can be the issue, so make sure they’re clean and tight. If everything looks good and it still doesn't work, it might be worth having a professional take a look. Good luck!
