Search Forums | Classifieds (191) | Skins | Language
Raven CR7 Pin Out Diagram
Ksbee
Posted 11/18/2023 11:28 (#10486953)
Subject: Raven CR7 Pin Out Diagram
NE Kansas
Working ground yesterday with a new to me CR7 and it randomly shut off and won't restart. About 30 minutes prior the screen dimmed itself randomly. Adjusted the brightness back and assumed I must have hit something on the screen I wasn't aware of. Now I'm thinking it could be related.
I did confirm there is 12v to the power outlet where it's plugged in.
I would like to try to power it up outside of the tractor by running power and ground to see if it at least turns on. Then I'd know if it's a harness issue. The harness is brand new.
Which pins power the unit?
