Central Nebraska | I figured out spraying that if I have a line that I've shifted to fit the pivot point, edge, etc the only way to save that shifted is to make a new 1. I engaged autosteer and made sure the sprayer was on the rows right and hit the swath recorder. Drove to other end engaged the whole time and set B then I had my new line. If you don't want to save it for next year, pull up your planter line and use the remark ( i believe its called). Poke that and it will bring up a box the says "set to current" and "edit". Choose edit and move it .5ft | |
