Search Forums | Classifieds (78) | Skins | Language
fore/aft value on implement receiver
kwsteve
Posted 6/3/2023 13:48 (#10255394)
Subject: fore/aft value on implement receiver
West Central Oklahoma
I'm using a greenstar 7000 on the tractor and a greenstar 6000 on the planter. My main objective with the second receiver is to create guidance lines for autopath. Most of the measurements have been pretty clear in how to measure except for the fore/aft value for the second receiver located on the planter. This value is entered in the setup tab for the receiver. Should this number be left blank, zero, or is there a measurement I need to add. I have values entered in the planter profile for the second receiver which to me indicate to the system where the receiver is located in relation to seed drop. The planter is a two point mount with lift assist and the mast is located approximately 26 inches behind seed drop in the middle of the planter.
While I'm asking, would there ever be a time when a negative value would need to be used for any measurements.
Thanks for any input.
