Eastern NC | Im assuming you mean a 4640 display.
First off, do you have the implement configured correctly in the display? When the harness was messed up something could have reverted back to default and unconfigured the rate controller from the implement profile.
Next, does the recording icon on the bottom of the 4640 show "auto" and does it turn green? If so, check your map settings and make sure you have the correct background map set that you are wanting to see. | |
