| It's a 4 pin Deutsch tower (DT) further up the harness towards the RSCM on the rate control side. I can look later if you still can't find it.
This is on the generic control harness. Raven harnesses may be different, I'm not sure, it's been too long since I've seen one.
Worst case is you could pin your cable if it doesn't have those pins instead of buying one, or maybe AgExoress could add it if the the harness isn't equipped with it.
All of our 10 year old or more generic harnessed do these the master/dump connector.
I'll double check when I get home. | |
