Northern Indiana | Haven't heard that yet out of a 2630, some 2600s are causing issues. You should definitely reach out to Agra-GPS.
I assume they updated your 2630 to the current 3.36.1073 that's been out for a long time. Is your tractor starting up good? Any battery problems? Make sure to go from key off straight to start, don't let it load up with the key on first notch then crank engine.
Something else to try is starting everything up with the CRG unplugged and let the 2630 boot up, I then plug in CRG. | |
