Search Forums | Classifieds (3) | Skins | Language
AgLeader RTK and Case AFS Steiger
WPFarm
Posted 5/7/2023 07:12 (#10218893 - in reply to #10212590)
Subject: RE: AgLeader RTK and Case AFS Steiger
SE MN
I'm running a similar set-up on a magnum 260. Pretty simple actually. Just buy the cable that goes into the second port on in command. This will provide the ability to supply correction to receiver and also NMEA to aux port on the nav. Need to make a cable to go from serial port gps out to 12 pin duestch (sp?)
