Search Forums | Classifieds (87) | Skins | Language
JD 2630 Steer On/Off Icon intermittent
nabh302
Posted 3/12/2023 16:24 (#10136435)
Subject: JD 2630 Steer On/Off Icon intermittent
Royal City, WA
I have a JD 2630 display and having issues with the Steer On/Off icon not allowing Autotrac. When setting up my client/farm/field, the steer on/off icon will show on a certain field I have selected in my list. For example:
If I select field #1 in my pull down list, it will load the data for that field and the steer on/off icon will appear on my home screen allowing me to use autotrac.
If I select field #2 in my pull down list, it will load the data for that field and the steer on/off icon is relaced with the book with wrench on top icon not allowing me to use autotrac.
If I swith back to field #1, the steer on/off icon will come back on my home screen.
Also, when starting machine back up after being off for hours, I go back into my gs3 equipment setup page and it always goes back to a JD 8285R setting (which is what it was used on previously in January) even though I have changed it before to a SP Windrower.
I am going to try another display in it tomorrow to see if anything changes. The 2630 monitor software is updated to the latest version as well as the receiver. I am not sure if it has a software issue but it was working in January on the JD 8285R. Seeing if anyone has had something similar happen, TIA.
